I have project coming up that I will using a DC motor in Vertical position,the Treadmill Motors I have are all open on the top end.I will shorten filter in pic and mount similar to Total Enclosed Fan Cooled cover to keep foreign objects out.
Oil Filter Cover for DC Motor
Originally posted by Duffy View Postsomething to think about---those motors are designed and built to run in a horizontal position. You might want to consider a thrust bearing.
Spoke to a fellow at Motor Rebuild&Refurbish shop he said they don't worry about vertical mount excluding very large motor 100HP and bigger
Originally posted by Tundra Twin Track View Post
Thanks Doozer&Nickel City Fab,I'm not concerned with running it vertical.It will still be belt driving so most will side load,have had numerous motors running Vertical on the farm over the years.Most recent a 10hp TEFC 1 ph that lasted 32 years in a very dusty environment and was wide open to all types of weather.
The bearing problem likely is not a problem IF the motor has ball bearings, as pretty much all that I have seen do. Any sensible ball bearing can take the minor end loading of the armature weight.
Plain bearings might be a different matter, they could need some form of thrust bearing.3751 6193 2700 3517
- 1 like
In defence of my suggestion an explanation. Back in the 80s, I was working on problems associated with dangerous fumes leaking into the mechanical penthouse of a laboratory. My employer, (Govt of Canada,) had built a new, largish laboratory, and not only did the penthouse stink, it stank dangerously. We had to identify and fix the problem or personnel would have to wear breathing apparatus to service the equipment. While "poking about," I found a "motor graveyard" in a room- a pile of 40 or 50 motors. Upon asking, it was explained to me that these had ALL suffered rear bearing failure. Why it took that many motors to determine the issue, I did not dare ask! This was the first new lab built in about twenty years. It had about 150 fume hoods and the designer had elected to exhaust them using vertical propeller fans-at the time, something new. It seemed like a great idea-less floor space, less ducting, and easier to service. BOY! did they need service! Changing motors. These were GE motors made here in Canada, however, the fan belt had to be cut off and the fan disassembled to install a new one, (nobody thought of link belt!) Eventually, GE determined that, for this application, the motors required a rear thrust bearing. My contribution to this "Chinese Fire Drill" was to identify that the contractor used chemically porous flexible connector fabric, allowing fumes to escape, (canvas REALLY did not work- we substituted vinyl.) Ah fun and games in the past!Duffy, Gatineau, Quebec
Originally posted by Duffy View PostIn defence of my suggestion an explanation. Back in the 80s, I was working on problems associated with dangerous fumes leaking into the mechanical penthouse of a laboratory. My employer, (Govt of Canada,) had built a new, largish laboratory, and not only did the penthouse stink, it stank dangerously. We had to identify and fix the problem or personnel would have to wear breathing apparatus to service the equipment. While "poking about," I found a "motor graveyard" in a room- a pile of 40 or 50 motors. Upon asking, it was explained to me that these had ALL suffered rear bearing failure. Why it took that many motors to determine the issue, I did not dare ask! This was the first new lab built in about twenty years. It had about 150 fume hoods and the designer had elected to exhaust them using vertical propeller fans-at the time, something new. It seemed like a great idea-less floor space, less ducting, and easier to service. BOY! did they need service! Changing motors. These were GE motors made here in Canada, however, the fan belt had to be cut off and the fan disassembled to install a new one, (nobody thought of link belt!) Eventually, GE determined that, for this application, the motors required a rear thrust bearing. My contribution to this "Chinese Fire Drill" was to identify that the contractor used chemically porous flexible connector fabric, allowing fumes to escape, (canvas REALLY did not work- we substituted vinyl.) Ah fun and games in the past!
One application that should not work at all is Grain Augers(some call them screw conveyer).Most of them use a standard type self aligning ball bearing with 95% of the load being end thrust and most last a long time.
