I have two Tormach tapping heads with TTS adapters. I wanted to be able to use it in a drill press with a #2 morse taper spindle so I bought a #2 Morse x 3/4" end mill adapter. It fit nicely except the set screw only catches the end of the Tormach holder so I needed to shorten it. In cutting it with a carborundum wheel it got very hot and I tripped the circuit on the table saw. So I finished using a 4-1/2" metal cutting diamond wheel on the hand grinder. In the process the hole apparently shrunk, the adapter no longer fits! How to open it up?
I am thinking lapping it using a wooden dowel as a lap and some lapping compound while it spins in the drill press. Without buying more tools is there a better way?
