Thoughts on this Hardinge HLV-H
  • Thoughts on this Hardinge HLV-H
    I was drooling over this thing when these people had their estate sale a couple weeks ago. They were asking 9 grand then. Now it is 7500. Worth it? The deceased was a tool and die maker, and everything looked well taken care of. They had a couple of series 1 J heads, but none of the tooling was for sale separate. You got a bunch of tooling with each machine.
    Early Hardinge Lathe that has had a recent spindle rebuilt. Comes with rotary phase inverter, collects plus, KDK tool post and 26 tool holders. Hardinge tools radius cutter, gears to cut metric...
    As the seller says; pretty damn complete.
    Fully accessorized.
      You couldn't buy a new machine with that tooling for that price. Not a steal, but not bad either. The deal I got my 10ee for I believe is once in a lifetime, so not comparable. Hell, it is only a a bit more than my Taiwan 1236 with all the tooling, VFD conversion, DRO, etc that I spent, and this is a hell of a lot nicer machine.
        Go see it, assess wear and general condition. Its not quite as much of a cream puff and I'd want for that money but not totally unreasonable. What year is it? The spindle rebuild concerns me - what happened? There sealed for life bearings not oilbath, with the later, the spindle should outlast the rest of the lathe....but I'd want to do some due diligence on what the norm is for the HLV . Abuse? accident? If its just age, is the whole thing just very worn? who did the bearings, and are they quiet and pass all tests with your best indicator? (runout, no movement radially or axially)
        Imo the price is full, lathe old and it doesn't look like a cream puff. otoh photo's don't always tell the story and they don't come up often. Only you can decide for you, for me it'd be a maybe pending a good going over
          I did not realize any of the Hardinge lathes had thread cutting capability.
          Lynn (Huntsville, AL)
            Probably one of the best small lathes for it, with that wonderful single tooth clutch you can cut threads at up to 1000rpm.
            As for the lathe in question the value is in the accessories. Some high-value stuff comes along with that machine and even if you didn't need a lot of it you could recover your costs by selling off the bits you'll never need and still end up with a very nice lathe if it's not worn out.
            As a bare machine it would be a definite 'no' at that price but the accessories make it a good price IMO. It's common for the compound slide base to be bent like a banana.
            Monarch 10EE 1942
              The HLV is the grand daddy of Hardinge lathes and one of the nicest tool room lathes every made....almost as a good as a 10ee
                Thats a really nice machine. I wish I could afford one of those
                  Love the HLV-H but if it indeed has had a spindle rebuilt recently you'd think the guy doing it would take some time to clean the front bearing cap.
                  www.thecogwheel.net
                    Put it this way: If that machine half as well tooled, was available for the same price within 300 or 400 miles of me, I'd own it already.
                    He has the Hardinge radius attachment- those alone go for about two grand. There's another grand-plus in KDK toolholders, if most of those collets are Hardinge brand, there's another $2K right there, and that nose-mount parting tool usually sells for about $750 on eBay.
                    Overall that's a hell of a deal. (Assuming something unknown isn't badly broken, worn or missing.)
                    Doc.
                      Put simply - If you have not already made arrangements to retrieve it, then you have wasted the effort of the post and the last 20 hours.
                        I am confused. Oil bath bearings should last virtually forever, but sealed for "life" only lasts the life of the lubricant. The bearings in our--addmittedly cheaper--rockwell are on their way out. Only a 40-50 year old lathe.
                          +1. Concur.
                          As with other posters, i'd already be on the case if i had the cash.
                            Although, that much money spent on a used lathe or any machine tool, I'd be looking for something CNC.
                              -Why? What if you're not doing production work?
                              Doc.
