I have a workshop lit with 8x 50W LED floodlights - 2 strings of 4, each string switched separately. When I installed them a year ago, they all worked fine. They only get occasional use. They are mounted on the original brackets (U shaped thing, 2 bolts into the lamp, adjustable) in a horizontal position, shining straight downwards. There is about 30cm of free air space above them.
The first one failed after a few weeks, and over the next 3 months, they all failed. One string blows the fuses when switched on, the other has one that lights very very dimly. Basically, all 8 have failed. I tried putting power onto the lights directly, no effect. It's the lights.
I bought a couple of spare lights at the time. I have one on test in the workshop. A thermal camera shows the back of the unit (which has fins for heat dispersal) running at 65 degrees C.
I'm suspecting that the circuit boards are overheating and failing. I pulled one apart. No transformer, just some surface mount circuitry on a circuit board that's bonded to an aluminium plate. It's not obvious to me what the circuit is, and the circuit tracks are between the circuit board and the aluminium backing plate. The plate is bolted to the aluminium casing, and there's thermal grease to conduct the heat. All Chinese made, but not too badly made.
I have found these: https://www.ebay.co.uk/itm/50W-100W-...53.m2749.l2649
COB LED's, complete with the driver circuitry, just add 220V. I've ordered 2. I then intend to mount a 120mm PC cooling fan on the back of the case to blow air over the weedy little cooling fins to keep the temperature down. I'll need a 12V power supply for the fans, connected to power to the lights, but easy enough. I haven't done any calcs on cooling, but a 120mm fan is the size that fits, it'll cover most of the fins.
Has anyone else had similar problems / experiences, thoughts? When they worked, they were great - 400W of light, instant on/off. I was very happy with them - for a short while...
Ian
Ian
