I have a few microwave transformers looking for a job. There are many build it articles on the web (for eg, https://www.youtube.com/watch?v=jSxOtDPh9Ew&t=333s) that are based upon them. More recent microwaves seem to be using smaller transformers (switching power supplies instead of "brute force" using 60 Hz?). While the videos give the basics, in general, to achieve maximum magnetism how important is transformer iron mass (are bigger transformers better)? Should multiple transformers be identical? How should they be wired (series, parallel or...)? Should the transformer(s) be tightly packed inside the case? Does the material thickness (mild steel) of the Base & walls matter - does thicker increase magnetic force? Would a cover (mild steel plate) increase/decrease/have no effect on the magnetic strength? Builders seem to favor DC. While AC (120 volt) might be acceptable I don't want to go where I know nothing.
How many pounds pull makes an acceptable vise? How could I measure it or is "management by result" suitable?
Any other thoughts appreciated. Thanks!
