Just thought I share the result when a few hobbies and professions meet.
Couple weeks back I shared a new lure design I came up with and printed on my FDM anet a6.
Since then I got an elegoo mars resin printer. The detail with that thing is pretty incredible. I liked the design, but made a few changes, mainly to the back tube flange, and figured out hook and line tie placement. Then I drew up a match plate and printed it. As well as some mold box ends. I printed it hollow with 1.2mm walls, and a 3d grid structure inside with a couple drain holes at the top (visible) and some on the bottom. The plate is 0.25" thick. The gunky looking dark spots around the parting lines is mold release, match plate pics are after pouring the silicone (too excited to take before pics
A few air bubbles highlight the fact that I need a vaccum pump to degass the silicone, but I'm pretty happy with the results of my first 3d printer related "casting". I'll have to wait a couple months to try it out with anything metal related (supplies to build a furnace are on the slow boat right now) but I'm really looking forward to it. I've got a couple months worth of ideas already.....
And last but not least, the maiden lure cast with alumilite resin. Missing the tube trailer, but I'm going to make those tonight maybe if I get some time. The internal wire is pretty rough, but I plan on making a few like this and if they work as good as I hope they do, I'll make an aluminum lead mold to cast the internal wire form. I'm also going to switch to a longer hook for a bit more throat. The back eye is for a stinger hook.
I had to go into the city today, so I worked a side trip to a 3d printing store to pick up some flexible resin to try. I'd like to try direct printing the molds to shorten lead times, and lower the cost per cavity a bit. I have a few ideas on how to print a cavity insert from flex, backed up with an fdm printed form with registration keys. Should be able to get away with a minimum volume of expensive flex that way. All in all the match plate idea worked pretty good though, and although I'd do some things a bit different next time, I'm pretty happy about the initial results. Even the venting worked great.
Hopefully I'll be able to test it out next weekend.
I know fishing lures isn't really that well aligned to the topic matter of this board....but I thought I'd share how a 3d printer can be used to make useful things and tooling, not just trinkets and benchy boats. I'm pretty excited to try the flex resin, and some burnable resin in the future when I get setup for casting metal.
