Turning head 90 degrees on Turret Style Mill.
  • Turning head 90 degrees on Turret Style Mill.
    If you have a B,port, clone or other vertical mill with full tilt head, tell us if you have turned it 90 degrees.
    What where you working on ?
    Have you ever turned 90, AND THEN HAD TO NOD , to line up to the work ?
    It's what i do normally when using my mill as a lathe... Click image for larger version
      I have a 90* adapter for my mill, so never really need to turn the entire head. Just put on the adapter
      sid
        Had roller from Combine that would not fit in Lathe,Varnamo got it done.
        You may only view thumbnails in this gallery. This gallery has 1 photos.
          Showoff...
          Keith
          __________________________
            Lathes.co.uk show a Beaver mill being used like this - scroll down for a pic: http://www.lathes.co.uk/beaver/
            Ian
            All of the gear, no idea...
              Originally posted by LKeithR View Post
              Showoff...
              Not Showing Off Keith just getting job done even tho it looks a little wonky lol!
                sid
                Ditto.
                  Check out RB211's current thread, "sometimes you just need a knee mill"
                    I can do that on my homebuilt minimill CNC. The head on my machine moves not the table so I can mill, drill or bore on the end of a part 20 feet long even if weighs tons!
                      I know...sometimes I really wish this site had smileys...
                      Keith
                        It does have them.
                        North Central Arkansas
