Last Saturday, Mike and I spent some time tramming the Tom Senior light vertical at the museum. It was slow and fiddly as we spent more time going the wrong way, and then the clamping up caused some slight movement. It is close, but not perfect.
What would be a reasonable tolerance, bearing in mind that the maximum size of shell mill used on it is likely to be no more than 80mm, 3 1/8"?
