Machine Tool Estate Sale (posting approved by George)
  • #16
    Originally posted by lynnl View Post
    Yes, one image is just a reversal of the other.
    In #19 it appears to be the LH end (note the wheeled cart on floor and brown box or stained block of wooden 2x4); in #18 those same features are seen on the RH end.
    First post, first group of photos, it appear #15 is assigned to both a small OBI and the Pexto.
    Fourth post, machine #1 is what? Guesses from several thousand miles away are okay.
    I will email her. Thanks!
    • #17
      I had a description with each photo but they wouldn't stay with the photo for some reason so here is the best I can do from 5000 miles away.
      photo 1. heat treat oven
      photo 2. metal cutting bandsaw, horizontal
      photo 3. Delta Unisaw 10"
      photo 4. CNC press brake for sheet metal
      photo 5. Pullmax sheet metal fabrication
      photo 6. spot welder
      photo 7. Pexto power shear, sheet metal
      photo 8. Pullmax sheet metal fabrication
      photo 9. C frame (incomplete assembly)
      photo 10. punch press
      photo 11. bar folder, sheet metal
      photo 12. punch press
      photo 13. power hammer head, blacksmith tool
      photo 14. arbor press, 3 ton
      photo 15. abrasive cutoff saw and Pexto corner shear for sheetmetal
      photo 16. drill press
      photo 17. vertical milling machine round column
      photo 18 & 19. Delta gang drilling station
      photo 20. Kent Owens horizontal milling machine
      photo 21. hydraulic press
      photo 22 & 23 bench grinder with belt attachment and bench grinder
      • #18
        Associated text for one image in Post #2:
        Click image for larger version Name: 09-Pexto Corner Shear and Abrasive Cutoff Saw.jpg Views: 90 Size: 277.6 KB ID: 1849135
        There seems to have been a recent forum update that has removed the feature that displays the text shown above when the mouse cursor is hovered over the image. You can view the "Image Info" by right-clicking on it and selecting from the drop-down control.
        USA Maryland 21030
        • #19
          These machines are more related to metal fabrication and metal forming than machining. A good site to post to would be metalmeet.com (there're a couple other sites which I don't recall the names of too).
          #13, the power hammer head and the two Pulmax machines are almost worth their weight in gold to custom auto body builders. And associated tooling for these machines is rare and valuable too. They're very sought after items. Since the owner had those machines it's likely he also had other specialized items that might not appear to have much value to the uneducated.
          • #20
            Yeah like the swage block on the floor in one of the pics.
            • #21
              The forum AllMetalShaping is very similar to metalmeet. There will deffo be more interest there.
              Richard - SW London, UK, EU.
