Continued over from another thread to avoid a huge hijack
The slow speed means that the energy would be low, so the flywheel would have to be big to do much. 3450 motor as RPC should then be better, faster speed is 4x stored energy for same mass as a 1725 rpm motor..
Voltage drops for two reasons....
1) load is on it and so it must slow to reduce back EMF, draw more current, and so bring torque up to match the load. Slowing reduces voltage in proportion. The generated leg voltage is just the back EMF.
If flywheel prevented slowing, it would keep that effect to a minimum.
2) impedance in series drops more voltage when current goes up. Flywheel would have virtually no effect on that.
The specific motor would determine which effect is the most important....
