I would be concerned about the amount of maintenance the old girl got, she looks pretty parched...
What model is this South Bend?
Originally posted by Ringo View PostDoes that make it the one they call 'Heavy Ten"
there is several 10" models,
the K is the heavy ten?25 miles north of Buffalo NY, USA
Originally posted by Ringo View Postif the ways are good, do you think it worth looking closer?
it a 2 hour drive for me?
for that price. I'm finding lathes in PA and Ohio for 2x as much and they don't look as good as this one.
So, yeah if the ways are good....25 miles north of Buffalo NY, USA
Originally posted by Ringo View PostI'm looking for a bigger spindle than my Logan 9x17. If that SB has in fact the same bore as the Logan, then I no longer need it.
But as soon as I find the correct lathe, the Logan goes up for sale.
And so does the 12x36 Craftsman/Atlas.25 miles north of Buffalo NY, USA
Originally posted by Ringo View PostOH, I think I got it now,
the light 10 would likely have a 9" 1 1/2-8 spindle?
the heavy 10 with bigger bore gets a D1 mount spindle?
hence the light vs heavy moniker?
Forgot to mention, if you can get the serial number from the owner, you can find out all about it either on the SB from on PM or get hold of Grizzly and they will copy the original bill of sale for youLast edited by nickel-city-fab; 01-29-2020, 07:53 PM.25 miles north of Buffalo NY, USA
somewhere on the internet I saw read an indication that this is a threaded nose larger than 1 1/2-8, maybe 2 1/4-8.
I got the numbers off this machine and now can't find that info.
this is a xxxxxKAX2
Does anyone have better info than I can find?
Originally posted by Ringo View Postsomewhere on the internet I saw read an indication that this is a threaded nose larger than 1 1/2-8, maybe 2 1/4-8.
this is a xxxxxKAX2
Seems to be a taper lock spindle (L-0) special order, with QCGB, 2nd revision. Dunno much else tho. If it is the threaded spindle, then it would be bigger obviously (2-1/8) but then the serial letters don't matchLast edited by nickel-city-fab; 01-29-2020, 09:29 PM.25 miles north of Buffalo NY, USA
