Radial Drill - How to Use / How Useful
  • #31
    All depends what type of work you do, unless you are just into collecting machines. I have a 2k, and use it often for all kinds of stuff. I also have a small 2ft, 1000lb radial made by Kira(japan) and it seems to handle all the work I need. The only times I seem to use it though is when I don't have enough height under the spindle of my vertical mill. If I had to choose between a radial and a 2k i would prob choose the k&t.
