Software for USB Microscope
  • Software for USB Microscope
    I needed a way to take closeup photos of my work and have been looking into USB microscopes. The first one I got was OK, but the photos weren't the best. So I got one of these Koolertrons because someone had nice images from them:
    https://www.amazon.com/gp/product/B0...k_ql_qh_dp_hza
    It arrived and I powered it up. It does make nice images but then the problems began. First, it apparently has zero internal memory so I had to purchase a micro SD card so it could save the pictures. OK, I got two for just a few dollars and now I can save the photos in the microscope. But then I found that there was no way that Windows would access those photos. Apparently some additional software was needed. I had a program from the other one, but it did not access this one. The instructions talk about using a program called AMCap so I downloaded the trial version of that. Now it recognizes the microscope, but it does not display the photos. I get an error message stating "Unable to add the video capture source to the video graph. Access is denied."
    Does any one have one of these USB microscopes? If so, what software are you using to import the photos to your PCs?
    Make it fit.
    Interesting - i have a very similar usb microscope https://www.amazon.co.uk/Microscope-...xpY2s9dHJ1ZQ==
    Like you i had problems capturing images until i came across this :
    https://www.supereyes-store.com/page...tware-download
    It's pretty simple to use and works well for my needs - YMMV...
    Cheers
    Batt...
      I use Canorama .... in Linux Mint.
        I don't use Windoze so I can't vouch for this: https://www.online-tech-tips.com/win...10-camera-app/
          Many later usb microscopes mimic webcams. See if webcam software works.
          Ed
          For just a little more, you can do it yourself!
            Yes, that seems to be one of the recommended uses for the program that batt-man suggested. I am going to download it if I can and try it. It was late last night and I am just getting back to the computer today. Probably another late night.
            I can't understand why there is so little in the line of INSTRUCTIONS. Their instruction book is a joke. And there was no software included with the microscope. And I can't find any help on their site on the web.
            Thanks for the responses. I will post updates.
            Ed
            Make it fit.
              I have a couple USB microscopes. The cheapest one was recognized as a camera by my Win10 camera app, and here are some images I took just fooling around:
              USA Maryland 21030
                "Win 10 camera app"????? Is that a part of Win 10? If so, where is it?
                Never mind, I found it. And it does recognize my USB microscope. Now I just need to figure out how to use it. It does not seem to have any method of looking at previously taken photos: I have about 5 or 10 in the microscope. Hopefully I can post a photo soon.
                Thanks!
                Click image for larger version  Name:	WIN_20200121_02_38_10_Pro.jpg Views:	0 Size:	38.6 KB ID:	1853640
                Click image for larger version  Name:	WIN_20200121_02_57_04_Pro.jpg Views:	0 Size:	33.4 KB ID:	1853641
                Click image for larger version  Name:	WIN_20200121_02_49_37_Pro.jpg Views:	0 Size:	46.9 KB ID:	1853642
                Click image for larger version  Name:	WIN_20200121_02_44_26_Pro.jpg Views:	0 Size:	54.8 KB ID:	1853643
                Make it fit.
                  OK, you got me going. THANKS! I am still going to try the other programs that I have and that were suggested.
                  Click image for larger version  Name:	WIN_20200206_00_TestPixOfSwitch.jpg Views:	0 Size:	95.4 KB ID:	1853656
                  Looking pretty good for a first try. The lighting needs some work but the detail is very good. Looks like this one is worth the price.
                  Thanks again. This board is great.
                  Make it fit.
                    there are softwares with angles and lines imposed on the screen for measuring purposes, a poor mans optical comparator of sorts. There are neat for looking at lathe tooling and carbide inserts etc. They work real nice for measuring angles of tiny pieces.
                      well, amcap does that.
                        +1
                        There is one program (freeware or "donationware") called Micam that does the this as well. I've used it with a number of cameras and USB microscopes. You can calibrate it to something that you know the measurement of and then use the on-screen scale to measure other stuff. Has been really handy a few times. You can download it here:
                        http://science4all.nl/?Microscopy_and_Photography
                        I'm sure there are others out there as well.
                          can you do angles in micam? i dont see anything like it.
                            Sorry, I think you are correct, it does not do angles. I am confusing that with some other SW that I had for such stuff. Have to see if I can find that.
                              Was wondering if you could recommend anything specific? A poor man's comparator seems very useful to me.
