A little HBM for the home shop
  • A little HBM for the home shop
    I thought HBMs only came in Large and Larger. This guy is so cute! 18" table.
    That would be a great HSM machine! Never seen one of those before.
      Yeah, I wish I had the space / need (ok, the space ). Seller says it's "rare" - might be true in this case. Has priced it accordingly, $11K Australian, $7,350 US. Plus 10% tax.
        After watching what Raymond Menendez does with a HBM on YouTube I'd clean everything out of my shop for one.
        Had no idea they are so versatile!
        Well, talent is required but...
        Kearns-Richards you say?
        Len
          I paid two grand for my Giddings Lewis 25T.
          It is 9,000 pounds of awesome.
          -Doozer
          DZER
            That is cute.
              -Doozer
              I am on the search.
                Me too! I'm amazed what he can do with that HBM.
                Yeah, made in the UK. Model is "S type".
                  OK, for those of us that are machine ignorant, what is the acronym HBM stand for? Looking at this machine how does this machine work? The chuck seems small but I'm sure I'm not getting the full picture . The tailstock does seem interesting as to what it might be able to tool up to.
                  Please educate me, sometimes I'm just slow
                  TX
                  Mr fixit for ths family
                  Chris
                    TX
                    Chris
                    HBM stands for "horizontal boring mill", its basically a boring machine laid horizontally.... usually made in giant sizes. Real handy for things like power plants, trains, and great big stuff. Usually a boring bar of some type in the chuck or maybe a big shell mill. Workpiece usually goes on the table. Here's an great example in action: https://www.youtube.com/watch?v=IR2p9ceg1bw
                      It's a Horizontal Boring Mill. The chuck holds the tool. The work is mounted to the table. Like a big boring head in a horizontal mill, but more rigid and able to change the bore size while the machine is running. I think the "tailstock" is for line boring (a boring bar supported at both ends).
                      Watch some of the videos on this channel to see what it can do https://www.youtube.com/channel/UC8_...nvZwJnw/videos
                      Reading a bit about this machine. It doesn't come with a "quill" like the larger machines do.
                        As I understand it, those are pretty rare. That does not mean I do not want one!
                        I have been using the H-Mill as a sort of HBM, but obviously the stroke and work envelope is pretty tiny. That one would be ideal for things up to reboring or sleeving smaller hit and miss engines, reboring most M/C cylinders/ engines and a lot of similar sized things.
                        And, as pointed out, for pretty general work per what Mr Menendez shows. You do need tooling.
                        The smallest size Bullard VTL would be OK too...... as long as we are talking about machines that I do not have room for in the main shop. They would have to go out in the annex/engine shed, which is currently unheated.
                          A nearby shop that I sometimes do subcontract work for has several HBM's. Last time I was there one of them had an angle plate on it that was 12 feet tall.
                            There's a shop like that in Buffalo, that I know of, he has a couple of HBM's with tables the size of my house -- as in, you could put my house on the table. He also has a VBM with an 18 foot chuck.
                              I wonder if the the table indexes, most do. Think machine one side of cube then table turns 180 and locks to work on other side ! Or 90 degrees.
                              plus you can run a line boring bar thru your work and support the end of bar, at varying heights.
