Show me your Carriage stops.....
  • #46
    Thank you as well.
    Yup. It will be a good read. I love all the articles. From the pic Geo posted it looks like you have been using it often. That front knurl almost looks brass. Thanks for the article Jerry... JR
    • #47
      Just wanted to check... Can you guys see the picture I re-posted in post #43?
      Chilliwack BC, Canada
      • #48
        yes
        • #49
          Three lathe carriage stops that I have made and find pretty handy.
          The first I made 30+ years ago, for a 6" Atlas. Pretty straightforward - two dowels pressed into the front block are a sliding fit in the rear block, with socket head screw to clamp. The locking handle on the stop screw was ground so it would lock in a convenient position.
          The second is for a 13" Standard Modern. 20 tpi screw allowed an adjusting dial with 50 thousandths markings. Screw has a keyway on bottom to keep it from turning. The clamping plate has two projections with half-round tops, just like some strap clamps. One fits into a half round groove milled into the body of the stop, the other bears against the lathe bed. I use this scheme often, as it gives good contact with no twisting of the clamp plate.
          The third is also for the Standard Modern, and is the one I use most often. Pretty simple - stop screw with lock handle, no graduations. But the long knurled screw on the front face is for mounting a lug back dial indicator.
          You may only view thumbnails in this gallery. This gallery has 3 photos.
          • #50
            Gentlemen;
            I posted this message on the Hobby Machinist Forum, but it's applicable to any of the 12"x36" import lathes that share a common 'ancestry'...
            take a look and see if you can use it!
            https://www.hobby-machinist.com/thre...ge-stop.90318/
            Best Regards,
            Lou O.Click image for larger version
