3 Phase motor missing wire tags help me
  • 3 Phase motor missing wire tags help me
    Need a hand
    Tag wires
    T4-T7
    T5-T8
    T6-T9
    T3 to power
    This where I need a hand
    ?? to power
    ?? to power
    If I disconnect all wires I should have a resistant between what should be T1 to T4 and T2 to T5.
    Everything else should be open.
    Click image for larger version  Name:	HSM_Motor.JPG Views:	0 Size:	114.1 KB ID:	1856999
    T1, T2, and T3 are power for series (480) and parallel (240)
    USA Maryland 21030
      Sorry I was not clear. I need to rewire to 240.
      I need to join T7 to T1 and T2 to T8.. The problem T1 and T2 tags are missing. How do I figure out which wire is T1 and the other is T2?
      If I disconnect all wires I should have a resistant between what should be T1 to T4 and T2 to T5?
        Yes. that should do it.
        USA Maryland 21030
          You got it. Since you have some of them ID'ed you're golden. If they were all missing you'd have to start from scratch.
          Central Ohio, USA
