Master of the horizontal mill
  • Master of the horizontal mill
    Thought yall might enjoy this master machinist if you haven't already. Hes in Spain.
    https://www.youtube.com/channel/UC8_...able_polymer=1
    I wonder how long it actually took him to make those?
    That's one big mill table. Just what I need to recut the miter gauge slots in my table saw.
    Noticed a couple bite marks at the front of the table.
    JL...............
      In the one I watched a while back he was actually using a horizontal borer
        I haven't watched any of his other video's, still have to finish watching the one on the diesel / electric locomotive.
        But I wonder how accurate the drilled holes were coming out the other side of the block and what his clearances were.
        JL..............
          I have watched all of his videos and he has helped me a lot. Not that I have a horizontal mill as large as a New York apartment... You can tell he's been working on that machine for a good long time by his economy of motion and ease with which he operates it.
          I have learned a lot watching his very versatile work holding techniques. Not too long ago I had to hold a large (to me) workpiece at 10, 15, and 20 degree angles to cut 3 beveled faces and I found myself borrowing an idea from one of his videos.
            I, too have been impressed. He's a journeyman HBM man. Back in the dark ages, I worked with a man who ground crankshafts with the same easy economy of motion. To very close tolerances. Almost looked like he was loafing, but he put out a large amount of work, and was highly respected by all of us.
            Oregon, USA
              This guy is awesome, uses a big hbm like a bridgeport.
                Yeah, a horizontal boring mill, which is what he uses, has an extendable spindle (just like a drill press) as well as
                the table for advancing a tool into the work. A horizontal mill has a non-moving socket into which you insert an
                arbour which carries the tool. A horizontal mill is most commonly used for making longer cuts in the direction of
                the 'X' axis of the machine--long keyways being a prime example.
                Keith
                __________________________
