Single pointing 0-80 internal thread
  • Single pointing 0-80 internal thread
    I don't post much here and this is my first time with the new format.
    I recently decided to take a crack at single pointing an 0-80 internal thread. The urge came about after Joe Pie did a video where he made an 0-80 nut using a tap. In the comments he spoke of trying to single point 0-80. I don't know if he meant internal or external. I make tiny model engines and have already single pointed 0-80 external threads. I figured what the hell and decided to go for an internal thread.
    A tool blank was turned out of 0-1 and hardened. The blank was then ground for clearance. This first tool broke on the second pass of my first attempt. A second tool was made but not hardened. The second attempt failed due to the tool being set to low. At this scale, it is very difficult to set the tool height.
    The third attempt was successful after the tool height was corrected. I decided for a 50% thread engagement using a #55 (.052) drill due to the great challenge involved with this exercise.
    For those who would ask why? The only way to get good at something is to push yourself.
    -Bob
    You may only view thumbnails in this gallery. This gallery has 5 photos.
    good stuff....thanks for posting some machining
      You may only view thumbnails in this gallery. This gallery has 3 photos.
        Originally posted by 90LX_Notch View Post
        For those who would ask why? The only way to get good at something is to push yourself. .....-Bob
        Bravo my Friend, Bravo !
        " A man has to know his Limits "- Clint Eastwood---Dirty Harry
        Rich
        Good job !
        Green Bay, WI
          Bob, You must be young with good eyes! Good job!
            Wow, nicely done! It's interesting to me how much more difficult something like this get simply due to the reduces scale of the work. Thanks for posting this, great work.
              Wow, great job. Feel free to post some more good stuff like this.
                Good for you!
                The slack in the half nut system of my old Logan would be enough to mess up threading that fine, so I would use a tap for it.
                  Outstanding ! You're gonna give Stefan Gotteswinter a run for his money !
                    You are a braver man than I!
                      Nice job! Are you going to try 00-90 next? 😀
                      Sole proprietor of Acme Buggy Whips Ltd.
                      Specialty products for beating dead horses.
                        That's just amazing... people who do small stuff amaze me.
                          That is an amazing feat. I don't think I've ever gone below 5/16". The advantages of single pointing is you can get that "perfect" fit that you may not be able to get with a tap, even with different H limits.
                          JL.................
                            I could NEVER manage that. Kudos, Bob.
                              Good for you.. no pain, no gain.. a lot if people should push harder and learn more..
