What did I buy?Anyone know what it is?
  • What did I buy?Anyone know what it is?
    Made in Sweden, looks old
    Early cordless drill prototype? LOL
      Victorian bedroom toy?
        Does not ring an immediate bell.
        But it appears to clamp onto a table, etc, and to spin the rod rather quickly, given the apparent step-up ratio. That suggests winding up something, perhaps a weaver's tool for winding yarn onto a spool etc.
        On a completely different tack, it might wind up fishing line onto a spool, or, perhaps, even a "lead" used aboard ship, although it looks somewhat light-built for use aboard ship..
        I do not see what would hold a spool or similar item onto the rod, there may be a key, or a threaded area perhaps? Or maybe it was just set up with a collar and thumb screw.
          I bought it because it was different & I'm ready to put the 2nd Gatling, a 22lr together & hope I can use it there. It's not as authenic so I can use a belt from the shaft to a cogged pully inside.
ID:	1858214Click image for larger version
ID:	1858212This is a bobbin winder for a floor loom. 6 or 7 careers ago, back in the day, my wife and I made handwoven clothing and did the craft fair circuit. A bobbin presses onto the tapered spindle for winding yarn. The bobbin in then placed in the shuttle of the loom and thrown back and forth to make the weft. I made several of these but with sewing machine motors than than hand cranked. Pictures shortly.
              Usually, the worm turns the gear, not the other way around.
                Also, some of the best know well reputed looms are from Sweden - Glimakra.
                  To me it seems the helix angle is optimized to provide an efficient transfer of power from the hand crank to the output shaft. It looks like what, about 5 to 1 step up, or more, you probably don't lose much energy driving the worm that way, and you get a respectable amount of rpm on the output shaft. Using todays lubricants this device would probably still work well.
                    Kinda brings to mind a rope twisting device, to me. Though I've only seen a couple.
                    A google for such brought up this ebay item, which, though not exactly the same, does seem to share a similar appearance for the gear casting.
                    https://www.ebay.com/i/362624460256?...yABEgKO3vD_BwE
                    Lynn (Huntsville, AL)
                      I think winding cord, rope or other fibers is what it is. Thank you!
                        you know, just because you put the word "Victorian" ahead of your answer does not mean it's right... I mean - it's not a picture nail fer cri sakes lol
                          Dang, I actually had the right idea.... I figured I would be totally wrong and it would turn out to be something off the wall..
                            How strange... i just noticed one of those on the local Swedish auction site. Hold on a minute.
                            Yup, it is precisely what mickeyf and J Tiers said-- a thread spooling device commonly used in association with weaving looms. Some folks also adapt them for use in tying flies for fishing, it seems. Not a rare item; there are lots of them.
                            That is a clever adaptation you have in mind. Lemme see what i could use one of those for...
                              No doubt about it. A bobbin winder for (hand) weaving. X wife had one. With a drop or two of oil they work very well.
