Nickel---what cad are you re-learning?--Brian
Thumper---A new 1 3/8" bore i.c. engine
Originally posted by brian Rupnow View PostNickel---what cad are you re-learning?--Brian
So now I am trying with a free 2-D program called Q-Cad and another one called FreeCad,(3-D) both of which run well on my computer. I need to learn how to set the application preferences for scaling to my paper size and etc. Also all kinds of basic stuff to save steps and save clicks on repetitive part positioning, dimensioning and constraints,etc.
35 years ago in college I was in the last class to have manual drafting. It is still my go-to, for now.Last edited by nickel-city-fab; 02-28-2020, 07:06 PM.25 miles north of Buffalo NY, USA
- Likes 1
I worked on the board from 1965 to 1995. Then I took a 6 week college night school class and learned on the famously horrible Autocad 13--(can you say blue screen of death?). I worked in Autocad until about 2000, then bought Solidworks and have worked in it since. I find that after 20 years of Solidworks I can hardly work in Autocad at all. You actually learn to visualize in 3D and then it's darned near impossible to think in 2D again.Brian Rupnow
Design engineer
Barrie, Ontario, Canada
Originally posted by brian Rupnow View PostI worked on the board from 1965 to 1995. Then I took a 6 week college night school class and learned on the famously horrible Autocad 13--(can you say blue screen of death?). I worked in Autocad until about 2000, then bought Solidworks and have worked in it since. I find that after 20 years of Solidworks I can hardly work in Autocad at all. You actually learn to visualize in 3D and then it's darned near impossible to think in 2D again.25 miles north of Buffalo NY, USA
Originally posted by nickel-city-fab View Post
Brian -- I would love to re-learn Solidworks 2012, but that is well beyond my means at this time. I had a year of it with MasterCam feeding into Haas machines at the community college back in 2012. I found out that I was far better at manual machining since most of my background is in repair. However, I did OK at the CAD (not great, but a good beginning).
I mean, maybe for your needs, 2D is all you need, but a whole new world opens up with 3D, including 3D printing, and large assembly design like my live steam projects.
And for me personally, I found parametric 3D CAD much easier to learn and much more intuitive than 2D.
- Likes 2
Originally posted by RB211 View Post
I'd highly suggest becoming a member of the Experimental Aircraft Association for the small fee, get access to Solidworks, you'll get the student edition Solidworks 2019.
One thing I loved about Solidworks is the ability to see how things are going to move, and potential interference. in all the simulations.Last edited by nickel-city-fab; 02-28-2020, 08:40 PM.25 miles north of Buffalo NY, USA
Allan Ostling
Phoenix, Arizona
Originally posted by aostling View Post
That gets me thinking about possibilities. Someday I hope to see modeling software which can include dynamic response to forces and pressures. This capability would enable an engine model to "run" in a virtual space. If it could simulate frictional forces (as from piston rings), and include basic thermal and fluid properties, a lot of product development could be done in software.25 miles north of Buffalo NY, USA
High end versions of Solidworks already do this. Those are add-on packages that bring it up to around $10k per seat license... You should see the ads in Aviation Week. There are also custom industry-specific versions that large companies paid big bucks for.
- Likes 1
Student edition of Solidworks included with the EAA has all the simulation features enabled. I tried simulating the motion of a valve gear on a locomotive and my computer at the time couldn't handle it in 3D. Solidworks however has a super nifty 2d sketch method of animating things which Fusion360 does not.25 miles north of Buffalo NY, USA
The flywheels will both be set up to flow air in the same direction. If they blew air towards each other or away from each other, I don't really know what the air flow would be like. If they both blow air the same direction, then I can be sure that they push/pull the air in the same direction, over the cylinder.Brian Rupnow
Design engineer
- Likes 1
The design is complete and the detail drawings are all finished. The only parts not shown on the drawing are the valve springs. I will root around in my stockpile of odds and ends to see what I actually have to start working on, knowing that I will buy the bulk of the material on Monday to really get into this.
Design engineer
The rockerblock is looking good!
Originally posted by brian Rupnow View Post...I find that after 20 years of Solidworks I can hardly work in Autocad at all. You actually learn to visualize in 3D and then it's darned near impossible to think in 2D again.
So what do you do when it's the middle of winter and you don't want to go and play outside?--Well of course, you make parts!!! I've rootled thru all of my scraps and came up with enough material to make the main rocker, the two cross pins for the ends of it, and the two spacers that keep the rocker centered in the frame. I have to buy a bunch of aluminum plate, but I've got enough odds and ends of material here to keep me busy over the weekend.
Design engineer
- Likes 3
