I'm planning a carburizing/case hardening experiment to alter high tensile (12.9 grade) bolt steel composition in the hopes of making it more hardenable and wear resistant. I need a cold working/die type of steel that could be hardened to extremes. For sure I could order a specific grade, but where's the fun in that
I noticed that 12.9 grade bolt steel supposedly has somewhat similar composition to O6 or some of the A group alloys used for cold working tools....that is if one could raise the carbon content in the bolt steel. In it's original form the 12.9 grade has quite low carbon content (about 0,3% assessable by spark test) and although it is tough as hell one can not really harden it any further with heat treatment techniques. Although it is possible to make it much more brittle by quenching.
I'm planning on running an accelerated carburizing treatment on a 9mm calibrating button that I machined out of the said bolt and see if I can get a really hard skin to form on the thing.
The process shall take about 7-8 hours out of which 5 hours are spent at 870C and the part is submersed in molten sodium carbonate/borax and carbon mixture.
I've used the molten carbonate approach previously for treating of mild steel and it really seems to accelerate the diffusion rate of carbon as opposed to just heating in the presence of a carbon source. Never tried it on alloy steel though....so it shall be interesting to see what happens. If it works at the same rate for alloy steel then I may expect the plug to carburize more than halfway through at the end of the cycle.
