Gotta keep an eye out for WIP
  • Gotta keep an eye out for WIP
    I don't mean Work In Progress, I mean bar stock Whipping around like a wet noodle
    https://www.youtube.com/watch?v=Qaulf8lipr0
    That one has been around for a while, but that is a new viewing angle. Same ponytailed guy though.
      Watching CNC machines operating is like watching RC airplanes--the crashes are the best part...😂
      Keith
      __________________________
        Hahaaa! That was the funniest one. Dude took forever to snap that GIANT red button. That lathe was not having any part of that noodle. Took it for a ride for a while. Ponytail dint even hit the brake.
        Umm, for the other cutoff situations at the lathe chuck. Yep, been there. JR
          That video is such a lovely reminder to check your bleeding setups before you start machining
            The only time I have had a shaft whip like that was on one where I expected it and so decided to turn the thing as slow as possible. It was a 13/16" diameter steering shaft from an old JD tractor about 6 feet long. The thread that holds the steering wheel on the taper needed building up and re-cutting. I welded it up and put it through the lathe head stock and thinking it would whip, I set the lathe for it's lowest speed, about 20 RPM.
            No sooner than engaging the clutch that shaft went nearly 90* and cranked into a cork screw shaped mess. Took me a half hour to press it back straight, then I put it back in the lathe with the outboard end stuck through a bearing made from a block of wood and clamped to a rolling cart.
