FYI; Burke #4, Hartford Craigslist
Originally posted by reggie_obe View PostHardly a basket case. Lead screws instead of hand levers, B&S #9 collets and it looks like the overarm is there, for $100, a steal.
A speedy little thing.....No back gears. Direct belt drive may not slow down enough, nor have the torque if it does. Maybe OK, but I'd question if it would handle a larger cutter well. Owners may have better info. I have back gears on my H-mill, and it does quite well with 4" cutters and slabbing cutters.
An arbor comes with it, apparently, but is the arbor type that uses a "center" on the overarm, good only for the lightest of milling jobs. You probably want one that takes an end bearing on a journal. Without back gears it may not matter, though, and it may also be possible to take the journal in the overarm even so..
it is also a mill with a SINGLE t-slot. I have a single T-slot on my H-mill, and I bet you swiftly curse out the designer who chose that setup. The options for work-holding are severely cut back by that single slot.
Depending how many B&S collets come with it, might be OK that way. Those are often expensive when found.
The $100 beats the heck out of what they often go for. And leaves cash available for the issues listed. You can get a couple arbors and still be under the common price by enough to get some cutters.Last edited by J Tiers; 03-14-2020, 05:59 PM.CNC machines only go through the motions.
I think Jtiers nailed it. Great deal for the money, but no doubt it has issues too. Most of those mills were made for production work, doing the same cut over and over, using dedicated work holding. If I was looking for a small horizontal right now, it would be the Atlas MF mill.25 miles north of Buffalo NY, USA
Originally posted by nickel-city-fab View PostI think Jtiers nailed it. Great deal for the money, but no doubt it has issues too. Most of those mills were made for production work, doing the same cut over and over, using dedicated work holding. If I was looking for a small horizontal right now, it would be the Atlas MF mill.
Len
