User Freindly Column Lock after 300 cycles
  • User Freindly Column Lock after 300 cycles
    Just updating on Column Lock I posted a while back,after over 300 cycles everything is tight and no additional movement on the lever.Very nice to operate from control side of the machine and not fiddling with two separate levers. Click image for larger version
    Nice solution, I also like the winch motor for the elevation.
      can you link to the build thread, I want to do that
      san jose, ca. usa
        Wierd: I got bored with the crank handle real quick,it's a pleasure to use with this setup.
        Gambler: Not much of a build thread just a couple pics,trick is to index the threaded studs or bolts to be able to tighten evenly.The top one I drilled indexed holes to be able to tighten it independently first then tighten lower one and install chain.The upper is 14T lower 15T that gears it up as upper casting swells slightly more with leverage of casting hanging out of Drill or Mill. Click image for larger version
ID:	1861662Click image for larger version
