I'm rebuilding a 1.5 hp 2J Bridgy I bought at auction and will post a thread on it a bit later. For now, I have a few questions about the spindle but first the critical information:
1) I made a colossal mistake in tearing the machine down before even running it (at the time, I was just planning on replacing the worm gear shaft that adjusts the head tilt), so the head is off the machine.
2) I checked the runout (err... whompeyjawdness) by laying the head down on a massive cast iron setup block and indicating the taper with a 0.0001 DTI while I turned the spindle by hand. Provided I was gentle so as not to cause any motion of the head on the block, I got an estimated TIR of 0.0003".
3) The internal taper shows some signs of abuse with some score marks. Later today, I will blue up a new R8 collet and take a print to see just how bad things are. Further up the spindle, where the little dog screw / key normally keeps the collet from spinning, is very torn up (a fairly common problem when a collet spins and buggers up the key).
4) The nose of the spindle has a few dings, also indicating a hard life
5) The spindle feels a little strange to me - a bit "stickier" than the J-head I rebuilt previously. I suspect this one has sealed ball bearings instead of the open, oil lubricated bearings on the J-head. Can anyone confirm that the 2J heads used sealed, greased bearings? Also, because I did not run it first, I do not know how much heat these generate, which might have been a good indicator.
6) Last night, I removed the quill from the housing so I could clean, strip, and paint the housing. The spindle remains in the quill.
General questions:
1) What additional tests or improved setups should I explore to test the spindle?
2) I suspect the bearings are probably okay - not spectacular but likely good enough - but I'm anticipating a bad print on the collet. If that's the case, should I send my spindle out for regrind and ask them to go ahead and replace the bearings? If I send the spindle out, will they touch up the outer diameter with the dings? Will they clean up the interior where a collet spun?
3) I have a very nice 6x18 surface grinder I trust and a less trust-worthy (haven't actually gotten it under power yet but is very crusty and dirty) KO Lee T&C grinder... you know where I'm going with this ... grind my own spindle?? It would take a lot of trial and error on blanks to get the taper just right and I'm guessing it's probably best to just farm this out but thought I'd ask.
A new spindle, without bearings, looks like it's about $750. Any ideas what it costs to regrind a spindle? I saw some references to a cost of about $450 through Wells Index but not sure if that's still accurate.
Thanks!
General questions:
Thanks!
