Need radius turned in OKC area.
  • #31
    That would be a pretty easy job on my cnc lathe but I am on the wrong side of the country. Cutting a nice accurate radius or ball is one of those things that a cnc lathe shines at.
    • #32
      J Tiers , Thank You
      • #33
        The OP never said that he'd been unable to find a local shop to do the job for him and was therefore searching further afield on this forum. As I said before there are local shops in his area that would probably be better prospects. I didn't say they turned him down. He didn't say he'd tried. The fact that he's trying the less-than-most-logical route just raises a question. So combine that with unanswered questions and it just didn't pass the sniff test for me.
        Many shops have had experience of accepting jobs that in retrospect they should have asked many more questions about, or the customer just gave them deceptive information.
        If someone wants to take this job on, they should just say so. What about you, Jerry?
        • #34
          Does anyone else leave the chuck key in the chuck while parting between centers, and likes to see how far you can chuck the chuck key?(If a chuck could chuck a key) How about taking your biggest chuck, extend the jaws out so only a couple of teeth are holding them in, and then overspeed the chuck as much as you possibly can while sticking your tongue out trying to just barely touch the spinning mass?
          • #35
            Are you saying that this endeavor might be hazardous?
            Dan
            • #36
              0
              I'm nowhere near him, or I might.
              But I do not have a radius tool anywhere near that size, nor do I really want to do that much large diameter 4140 on the old 10" flat belt Logan. It would fit, but that's a big volume of tough material to remove, if it is the HT. Less so if the annealed, but still takes power.
              It sounds like the OP has a better suited machine to that job, considering the D1-5 spindle, and may want to just suck it up and do it. Should not take that long on his machine. It would just take too long on mine, and I'd need to make a radius tool that I'd not need in future..
              TGT I may have been too tough on your reply..... you have my apology. Sounds like I just got the wrong "take" on what you wrote.
