cutting small tiles by hand
  • cutting small tiles by hand
    Anyone know where to get a used or cheap bench shear for cutting small tiles by hand. Or somehow make one???
    Home depot has tile breaking devices cheap. Under $22 IIRC. You score and then bend along the line and they cut cleanly. https://www.homedepot.com/p/ANVIL-14...4ANV/304747845
    I'm not sure how small your tiles are, but that worked for me when I needed to fix some 1x2 inch tiles around my bathub.
    Dan
      Thank you for answering so very fast.
      I have a 24" tile cutter like that....but I can't control tiny (e.g.up to 1" tiles). I'm hoping for something more like small bench shears.
        Rose, a diamond blade on a small angle grinder might be a better way to go. Jim
          I used a diamound blade on my table saw to trim and fit tile, worked really good.
          Jon
          SW Mi
            If you can't find anything else you might make a cradle for the small piece to hold it in position. Now that I think about it, I also I bought tile nippers (https://www.homedepot.com/b/Flooring...,6678,635,1017) for under $20 when I was doing that bathroom remodel.
            Dan
              I've got a set of pliers that are like a small brake, with a scoring wheel on the backside. They work great for small tiles. Did my old kitchen in small mosaic tiles and they paid for themselves very fast. I'm pretty sure I got that at home depot, but it was about 12 years ago. I'll see if I can dig them up tomorrow and snap a pic
              edit: Dan posted as I was writing. Mine are like these https://www.homedepot.com/p/QEP-Hand...024Q/203265734
              I've got some nippers too, but didn't find them as usefull for clean cuts.
                Home Depot sell tile nippers. The HDX 8" nippers work well. if you are cutting them attached to each other in a sheet the 4" grinder and a dry cut diamond blade works well.
                  Nippers, and then clean em up on a dry diamond angle grinder clamped in a vise. Honestly, I've handheld small pieces up to the blade of my 10" wetsaw just fine and used it like a disk sander.
