At 100K miles I'm going to change the gear oil in the differentials on my truck. And of course, that hole is not easy to get to. In the past, I had to buy the oil by the quart and use one bottle with the spout to squeeze oil in. You couldn't squeeze but about half of it, then you had to refill it. What a pain, but I that was 30 years ago! Anyone have a better/easier way? I hope?
OT- Putting Oil In Differential
Originally posted by A.K. Boomer View Post5 bucks gets you a pump mechanism --- attach to gallon jug of dope and put hose in fill area, done deal...
Just a short piece of hose (6-8") shoved tightly onto the nozzle allows you to swing the bottle vertically, which permits the bottle to empty. A piece of radiator overflow hose works really well - it is a good diameter, doesn't kink easily, and is more flexible than fuel line.Location: North Central Texas
Originally posted by rws View Post
Can you give me an idea of a pump you talk about? I looked on Autozone website, they have inexpensive "transfer pumps" but all they say is for "fluids". 90 weight gear oil isn't a typical fluid to pump I wouldn't think.25 miles north of Buffalo NY, USA
wot 'e said ^.
I bought a couple of these off Amazon
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
have one for the CVT and one for the diffs on my Subaru. Pumping 6qts into the CVT gets old under the car, but it's not like I have to do it every week
quick tip I read about once. If you're refilling your diff, make sure you can unscrew the fill plug first. If you empty it before that and the fill plug is seized, you're kinda screwed. Also get any specific gaskets or gasket maker first.
- Likes 1
Lots of really good advice already about pump dispensers and funnels with hoses, you can even buy the funnels with the hose permanently attached.
One other tip that is worth mentioning is to pre-warm the oil before you pump it or pour it down a funnel with a hose.
Not sure of the ambient temp at your location but it really speeds the flow up if your oil and dispensing equipment is nice and toasty.
Straight 90 weight gear oil can be the consistency of an SAE 60 weight motor oil, the more common 80/90 or synthetic 75/90 gear oil is much more fluid at low temps.
But warm temps are still your friend.
- Likes 1
Originally posted by nickel-city-fab View Postwhen I was really young and cheap. I used a length of old hose long enough to hang the bottle from the bumper, upside down.Location: Saskatoon, Saskatchewan, Canada
- Likes 1
You can use a pump that fits the bottle.
But this is what I do at work. Get a cheap garden sprayer at Tractor Supply, cut the nozzle off so you just have a open tube, put whatever hose or other doo-dad you need on the end to get to the differential fill hole. Dump your lube in it, pressurize the thing and open the spray valve. I use a big O ring that fits over the handle and valve lever to hold it open. Gear oil moves slow, but it works well. I use it for filling transfer cases also.
Filled a Dana 80 with it last week.
There was ZERO chance I was going to get the fill plug out of my Chevy truck (2004 vintage) differential. Rear cover was rusty so I bought another figuring I would add a fill plug bung to the cover before installation. When I got the cover it already had a fill plug in it. Guess I wasn't the first to have the problem...
Originally posted by strokersix View PostThere was ZERO chance I was going to get the fill plug out of my Chevy truck (2004 vintage) differential. Rear cover was rusty so I bought another figuring I would add a fill plug bung to the cover before installation. When I got the cover it already had a fill plug in it. Guess I wasn't the first to have the problem...25 miles north of Buffalo NY, USA
