Van Norman Milling Machine Craig's list
  • Van Norman Milling Machine Craig's list
    Worth the time to rebuild it?
    https://rapidcity.craigslist.org/tls...096521953.html
    Might not even need rebuilt. For sure it'll outlast most of us.
      What makes you think it needs a rebuild? Looks pretty nice to me and the price isn't bad. Who knows what the accuracy until you use it.
      If however you need the absolutely actually that a rebuilt machine would provide then you'd be money ahead to spend the $7K and buy a new quality Taiwanese turret mill.
      Central Ohio, USA
        It was just painted and I'm not that optimistic. 800 bucks is too good to be true. and.... I'm just trying not to buy it, yet maybe?
          Yeah but the ad said it was re-scraped in 64 and still pretty tight. Way I see it is, what'll it cost to go look it over in person?
            Yep, if you are close go see it. Not anything else you can these days other than stay home in the shop.
            Central Ohio, USA
              I'd buy it if I was nearby, it seems very likely a good buy. (I'm a hobbyist and I have an much more antique Van Norman and an Excello, about 1200 dollars purchase cost in total for both of them.)
                I saw Van Norman and inside my head heard Rube Goldberg... then I saw the funny way it converts from horizontal to vertical...
                  No tooling and 5V is a bit oddball taper, no arbors or arbor support.
                  I would pass.
                    I would pass.
                    Thats probably why the price is so low. Its a regular feature on PM to rebore VN spindles for more common tapers such as CAT30 or even R8
                      The price isn't low for a machine with no arbors, arbor support or collets.
                        I rescraped the knee for one of those a while back (customer did not want the whole deal done). Was not too bad to do, but it's a heavy sucker. Would not want to go through the whole thing.
                        Some of the gibs are a bit odd, they are a bolted down design. I had to mill one down to match the scraped worn surface. Good job I did not need to mill anything on the knee, as I had nothing that was big enough to do that.
                        Was trying to recall if that one was a Van Norman, until I saw the off-center handwheel in the CL pics..... yep had to be.
                          Not looking at the pics right now , but if you can mounta Bridgeport head it would cure the ills.
                            It was nice of the seller to leave evidence that he gave the machine a cheap cosmetic treatment with a spray can. But I have one of these of about the same vintage (late 40s), and it is a very good machine. It's true that 5V tooling is hard (and sometimes expensive) to come by, but you can do a lot with a single shell mill arbor. Note that the overarm support for a horizontal arbor is missing, and the versatility of the machine is greatly reduced if you don't have it. They are almost impossible to find, although I had two at one time. All of that said, it might be a very good deal if it powers up and if the X-axis table feed (from the motor in back) is operational.
                              I'll sell you all my tooling, overarm support, table end stops, slotter and toss in the mill for free.
