I have what was touted as a 7000watt system when I purchased it. It has never created more than about 5500whrs.
When I take the trash out I always glance at the display, shady side of the house, for diff reasons.
The display showed 6+kWh's going on. It has never been in the sixes.
The sky was bright but scattered low clouds.
Could that actually amplify the Suns energy?
I think I heard it first from AKBoomer. He had a reasoning for it. It has been in place for prolly seven years so I look at alot. Never seen it that high. Yeah.
EEs will say the Inverter is failing to give proper info. Oh, edison has one of those smart meters they clamped to my house. I could check it with their A/C Digi meter.
Only way I could bleed off 2-5kwh. Otherwise I would have an electric bill of 400 a month so edison it is. I would like to be off their grid. My Inverter doesn't
It was odd for this thing making more than ever with low clouds and I am NOT complaining. Now I can do some welding which eats the most.
JR
Well?? Failing Electronics, Sky clouds (AK) or UFOs?
The machining related stuff is in the Narrative, please look. Thanks. JR
This is the end of day power. Still trying to click along.
Its been a nice day.. JR
JR
