vnmg insert size
  • vnmg insert size
    I am looking to get some vnmg tool holders and inserts for general profiling on my manual 16X60 lathe. I see there are two different sizes available, the 431 style and the 331 style size. Which would be more appropriate for the size of lathe I have? Thanks Paul
    The larger would match your lathe better.
    I bought some of the smaller size in a job lot and got toolholders for them in left and right. They look fragile compared to other styles of cutter, I would hesitate to push then too hard.
      .I use mostly 3/8 IC size on my 13" lathe (33x). They're a little cheaper, and the holders come in smaller shank sizes. That being said, if you're going to take heavy cuts, spending the extra might be worth it.
      Oregon, USA
        Thanks Old Mart and Tim
          400 series. Its a big lathe. I mostly use 300 series size for my use and inadvertently get some 400 sized stuff (neg rake) I cant use. Ill though a few in a mailer and let you see if that is the correct size for you.
          On a side note my best bud would use the smallest bit on a 16" ReedP. Never broke a bit, just wore them out LOL Del....
          Anyway, if you want a couple of VN bits lemme know. Might have a holder also but that you paying shipping. Lemme know... JR
            Thanks JR, I sent you a message, Paul
