Originally posted by Mcgyver
View Post
A level does not have to be on the Kingway, and that may not be the best place if you have just one level. Use for measuring "level-derived-angle" to check flatness or parallel is not the major value of the King-Way to me. (see last bit below)
And, yes I have, if you want to count a bit over a metre long. My straightedge was somewhat short (775mm), but I stepped it over. I expect that with the reasonably long straightedge it was more accurate than a much shorter level base in many more steps. Then a level set crosswise at the ends to check for "wind". I have a good Taylor Hobson level, it just does not go on the King-Way
The level can get you close, probably NOT as close as a good straightedge, or there would be no long straightedges, but there are.
If you want to get accuracy on longer beds, where your straightedge is too much shorter than the bed, the level is the secondary or "make-do" way, the right way is the autocollimator Yes YOU can DO it with the level, but a good straightedge, or best, an auto-collimator is the "right" way to get accuracy.
The level tells you which way the surface is going, where the level is. it does not tell you how far the surface HAS gone. You have to add up all the intermediate steps to get that. OR, if you HAVE a long straight surface, and the level says it is level along the length (within the error of the level) then you can be fairly sure you are level overall, at least to a few tenths per foot, or perhaps a thou or two over the length of a bed. Then if another surface gives the same result, you can feel reasonably sure they are parallel within a few thou error, depending on length.
The autocollimator also does not give you a distance, but it tells you the angle over the distance, which comes to the same thing. If you had a level that spanned the entire length, that would be a similar measurement to the autocollimator, although not as sensitive. The autocollimator is good to an arc-second or so if it is an old visual type, which is what hobby types might potentially have. The level is calibrated to 8 arc seconds or so, and estimated to a bit closer. (I know people around here who have such things, Talyvels, autocollimators, etc.)
To me, the value of the King-Way is in the way it can be set up to measure the RELATION of one surface to another which it needs to be parallel perpendicular, etc to. In the Connoley book, there are a large number of "measurement setups" using various specialty frames and indicators. The King-Way can duplicate most any of those quickly and easily.
