I'm in the process of refurbishing the alloy wheel rims on my car. The rims are 19" BBS Speedline split rims - like these: https://www.ebay.co.uk/itm/GENUINE-A...-/253815831300
They each have 19 M7 bolts with 12 point heads. the 20th hole has the wheel valve in it. So 76 bolts. 75 came out in one piece. They were all tight, needing an impact wrench or a breaker bar to get them loose. They were all covered in white oxide from corrosion, and a blue sealant - looks like Loctite 222. But they came out.
Then there's number 76. That one snapped off just below the head. I separated the barrels from the centres, and there's about 6mm of bolt sticking out. I tried a tiny pipe wrench on it, but it's stuck far too solid for that.
Plan B is to bore the bolt out in the vertical mill. I flattened the broken face of the bolt with an angle grinder (also thinking the heat from grinding might help). The sparks that came off were very white - tiny tinge of yellow, bushy and bursting at the ends. It was tough to grind. I ground the end of a file in the same light - much darker orange sparks.
The bolt is not magnetic and is corrosion resistant.
Could it be titanium? I can't imagine a 3 series stainless steel being that hard, and a 4 series would be magnetic. Some vendors do sell titanium bolts for these wheels, I just can't find what the OEM uses.
New rims are $shocking. Suggestions on how to remove this bolt?
Ian
Ian
