I'm going to attempt turning a ER32 collet chuck for my Logan, 1 1/2-8 threaded spindle.
I have one of the 5C chucks for it, and it is big, takes up a lot of room, feels like burrs or sharp edges in the scroll, and have had previous issues with runout.
So I will attempt a ER chuck. Spindle bore for 1 1/2-8 nose is 3/4", so ER32 will do. The same collets and collet draw nut, wrench will fit the new R8 item I just ordered.
Seems I use 3/4" dims most often as straight shanks, or blank drill rod, or whatever. ER32 made sense for me to go back forth of mill and lathe.
This will be quite the adventure, at least for me, and my machines.
I'll be internal threading to a tolerance,
internal taper boring to a tolerance,
and metric threading on a american lathe.
This could be the trifecta of goofballs.
Here is the material blank next to the 5C chuck,
