I am in the process of purchasing a Bridgeport by Adcock and Shipley with the 2J head. I live in Australia and my shop only has 240V single phase power. The mill I am considering has a 415V three phase pancake motor and obviously I need to find a solution for powering this mill. I initially thought it would be simple. Just get a variable frequency drive to convert the 240V single phase to 415V three phase. But, you guessed it, it's not that simple. I have previously used VFD's on two mills and a drill press. The two good ones were Invertek Optidrives and the drill press has a Huanyang el cheapo drive but it works OK.
My research so far indicates that:
(a) 240V single phase to 415V three phase VFD's are mighty thin on the ground and hideously expensive.
(b) rotary phase converters are expensive, noisy and lack some refinements that VFD's offer.
(c) swapping out the native pancake motor for a single phase motor or a 240V three phase motor is not that simple on the Bridgeport 2J model due to the long overhang required on the motor shaft
(d) fitting a more commonly available 240V single phase to 240V three phase VFD will derate the motor torque considerably.
However; I have found a vendor who will supply a "1.5 kW (2HP) Single Phase 240 V to 3 Phase 0-415V Variable Speed Drive, VSD, VFD" for just over AU$1000.
https://www.ebay.com.au/itm/1-5-kW-2...97.m4902.l9144
My question is: has anyone used one of these/purchased one of these/ rejected one of these on sound advice/considered one of these or experienced problems with one of these?
I don't mind paying the (high-ish) cost if it does the job. But I don't want to use a VFD if it hobbles the torque of the motor.
Advice is welcome.
Regards,
Mark Presling
Advice is welcome.
Regards,
Mark Presling
