W&S Cutter Grinding Gage?
Looks like it is a crude (stamped sheet metal) gauge for grinding tools to those two or three angles. I say possibly three because there appears to be a third angle along the top edge, possibly for negative top rake on a lathe tool.
Is it useful in a home shop? Well, if you need one or more of those three angles, with only marginal accuracy, then by all means, use it. Personally I would toss it in the scrap steel bin and use it when I need a piece of unknown alloy steel about that size. Or is it aluminum?Paul A.
Originally posted by Paul Alciatore View PostLooks like it is a crude (stamped sheet metal) gauge for grinding tools to those two or three angles. I say possibly three because there appears to be a third angle along the top edge, possibly for negative top rake on a lathe tool.
I'd put it up on Fleabay and find a buyer.
It's similar in function to these. https://www.ebay.com/sch/i.html?_fro...te=1&LH_Sold=1
- Likes 1
