Hi,
I have a MW/Logan 2136 lathe. I have not used the power feed in quite some time and last time I did it seemed fine, but now it makes a knocking/clunking noise when the drive is engaged. Same noise level and frequency in either drive direction-this is just with the gear box drive engaged, not the cross slide or apron. Nothing obvious that I can see from the outside but wanted to ask for advice as to what to look for when I take the box apart, and any suggestions as to how to do this. The lathe has been moved (without disassembly) twice in past few years, and I did remove the spindle once to replace the drive belt.
Thanks,
Bob
Thanks,
Bob
