Originally posted by Ringo
View Post
The full size tray is nice in a lot of ways. But both the one in 19 and mine in 93 don't leave much room for sweeping things away. If you have the tooling to allow making them I would heartily suggest the riser blocks you were considering early on to raise the lathe up above the tray and allow easier working underneath. The trick will be making the risers such that the surfaces are dead flat to each other. If they are not on the same plane then the risk is that it will try to bend the bed into an "S" like shape.
Mine is so bad that I rely mostly on some raking sticks to clean out the swarf and bring it to the front of the tray. It's rather annoying to use them but makes the job workable enough that I'm not going to bother with trying to lift the machine off to install spacers at THIS point. These rake sticks are made from oak so they last reasonably long and are 1/4 x 1" with the edges "sharpened" by angling at around 20 to 30 degrees instead of being square.
