I have a bunch of kennemetal insert Kc810 and my insert holders use a 4mm screw. The holes in the Kc810 inserts are about. 008 smaller. Any practical way to open the holes?
Open the screw hole in carbide inserts?
Check whether the hole has an angled front end, you might need longer screws if only the parallel part is opened up.
KC810 is the grade, what inserts are they?
3.5mm is the more common size of screw for middling size lathe tools, although I have 4mm used on some shell mills.Last edited by old mart; 04-25-2020, 03:44 PM.
- Likes 1
I think diamond would be pretty slow for removing .008. And there's the risk that if you're going to remove more from one side than the other.
What about making a new holder that uses a clamp down finger? The finger could have a conical feature that fits into the hole and pulls the insert against the back corner at the same time it pushes the insert down firmly.Last edited by BCRider; 04-25-2020, 02:59 PM.Chilliwack BC, Canada
- Likes 1
A diamond in a dremel tool was a waste of time. I could see right away that it wasn't doing jack.
I think I'll just make a tool holder for these inserts and use the right screw.
So the ANSI screw hole is 3.5mm?
As for the nomenclature I'm still working on it. They were loose and without any label.
My best guess is that these are TAMH2150.
Triangle, 3* clearance,.0005 tolerance, single countersunk screw and molded chip breaker.
Originally posted by old mart View PostStart by identifying the inserts:
http://www.carbidedepot.com/formulas....htm#thickness
Originally posted by challenger View PostA diamond in a dremel tool was a waste of time. I could see right away that it wasn't doing jack.
Are you positively sure about the clearance angle?
So these are SINGLE SIDED?
Pictures would be greatLast edited by MattiJ; 04-26-2020, 01:44 AM.Location: Helsinki, Finland, Europe
- Likes 1
