Its Finally Back down to 92F In My Office
  • Its Finally Back down to 92F In My Office
    Yep, that's right. "Down to" 92F... and it feels so much cooler than it did a little while ago.
    Ok. I'm cheap. I admit it. I had not yet turned the air conditioning on in my office this year. I was in the machine room doing cleanup and it was getting hot, so I opened the door to the office, set a fan in the doorway, and turned on the office air conditioner. It felt like it was just getting hotter and hotter. I said the heck with this and headed into the office to cool down. It was like jumping out of the oven into the furnace. Holy crap it was hot. I put my hand up in front of one of the AC vents and it was blowing HOT (as in heated) air. After some testing I found the AC worked if I manually connected the wires (heat pump reversing valve and compressor to control power lead.) I figured the control wire was bad. Its UV rated, but this is Arizona. We don't have UV. We have Super UV.
    I pulled up some wire, cut it off shorter and rewired it. I had left excess inside the building by the air handler knowing in 15 years or so I'd probably have to do that. Now nothing worked. Crap. I had disconnected the control hot before cutting the control wire back. I just forgot the control power comes from the air handler. Not the compressor. I opened up the air handler, and replaced the 3 amp fuse. Now its down to 89F in my office. Its starting to feel almost frigid.
    For a few hours it was cooler out in the shop than it was in the machine room or the office. Might still be.
    It's no wonder it's so hot in your "Arid-zona" state. You have Two-suns (Tucson)!
    USA Maryland 21030
      I was about 30 miles past Willy,s place at 2 pm today.. Click image for larger version
        My buddy retired to AZ and sent me this for my desk.
        S E Michigan
