I am in the process of doing some maintenance to my Novakon NM-135 mill. X Axis backlash is 0.006". I took it apart to take some measurement. The current X Axis ball screw is 20mm. It is a block ball screw, not sure if I explain that correctly. It is a 1 piece block 36mm and the ball screw cartridge is mounted inside of that block, cannot take it out.
Anyway, the current 20mm ball screw cartridge/flange are much bigger than this old one. There is no way I can mount it in, even if I machine the casting.
I can get 16mm ball screw easily that would fit with minimal machining. It is a pretty small machine, is there any risk of going to a smaller ball screw? As an example the Y axis is 14mm??? I don't think you can get 14mm ball screw anymore.
Thanks
GST
Thanks
GST
