I just picked up a surface grinder after looking for one for a long time. I had the seller drain the hydraulic fluid before I brought it home so it didn't splash all over the place. Today I put in fresh hydraulic fluid and ran the grinder with the X feed working: http://nwnative.us/Grant/images/itsAlive.mp4
If you turn up the volume you will hear how my hydraulic unit sounds. The rotation is correct i.e. not running the pump backwards. I don't believe the noise is coming from the electric motor - I've heard lots of motors run with bad bearings and this doesn't sound like that. Here is an image of the hydraulic pump. Highlighted is a zerk fitting near its input shaft. I want to try lubricating the motor but I know some machines use zerk fittings for oil and if that were the case I wouldn't want to pump grease in there. How to tell?
metalmagpie
metalmagpie
