On my on going balancer project, originally I was going to use the super bright led clusters for a strobe. Pretty sure it will work, you even get enough of flash off a largish single led, but then this bench strobe popped up for small dollars. Its got a trigger, but I'm kind of stymied what it expects, with a 7 pin connector. Usually there's lots on the net about older equipment, but I could find nothing on this one.
Anybody have one, access to a manual or is there any sort of trigger-in standard? Suggestions?
thanks
thanks
