I ordered this guy about a couple weeks ago, and it arrived last Friday. I think this is the longest I've left a new toy in the box. One of the reasons for the big garage makeover today was to find a spot to play with it. Took about 35-40 minutes to heat up to ~720*, and I gotta say I'm pretty impressed with it so far, and pretty hooked with the process of casting now. (I moved the bucket of kitty litter after taking the pic). My only gripe was the opening needed to be filed larger to fit the crucible all the way in. I'll need to file it some more as when hot the crucible expanded a bit and made it tricky to get out.... The lid does feel a bit cheesy too, but it does the job required of it.....The tongs are a bit iffy also, but they are better than the welded style that sometimes come with these things. The bottom line though, it melts metal
I welded up a little ingot mold from bed frame, and a slag scraper while it was heating up. First go round was just some scrap 6061 parts, and some cast pistons from an air compressor to try it out. I have a bunch more aluminum under my porch steps to haul out and melt down. A bunch of scrap copper too and I want to try some aluminum bronze as well.
First charge
First pour ready to go after scraping the slag off.
And the result. I stopped to adjust my grip on the second ingot and it froze up so I just moved to another.
My first "castings" after a quench in a bucket of water.
I was originally going to make one, along with a bigger propane fired foundry but just never had the time to get around to it. I have projects I want to make and get tired of the "make a tool, to make a tool, to make a part" process so I decided to just buy some time and ordered one instead. I'd already ordered a couple pids, and another 3kg crucible back in the winter, so I may still build one eventually. I put the other stuff to build my bigger one on hold after getting laid off last week until work picks back up. I've been following the home foundry boards on and off for years, so it's nice to finally be able to DO it. Even if it's just casting ingots.
Now to get the 3dprinted pattern--->cast aluminum part process down. I've been consuming seemingly every you tube and forum post on it all winter long, and have also come up with some of my own ideas, so now I just have to get to it and see if they work.
A full "3kg" crucible will get me 3 full ingots probably (if I don't stop pouring to adjust my grip.....), and when cold I can fit 2 of them in the crucible. I made the mold that size so eventually I can bulk cast ingots with the bigger one for use in this little one.
First charge
