I'm motorizing my bead roller, using a GM flexplate and starter pinion for 18.66:1 reduction between a 100 rpm gear motor and the driven shaft. To connect the motor shaft to the pinion I need to modify the pinion, which is HARD. Does anyone know whether such pinions are hard all the way through or just case hardened? Thx.
How hard are starter pinions?
I doubt they are hardened all the way through. Probably a case hardening of sorts. I say this as the whole starter drive assembly is not all that overly expensive. You see the ring gear they engage with receiving the most damage from the drive & then requiring replacement. The damage is likely the result of the engine stopping most frequently in the same spot. Strange but true.
Doozer, That might have worked if requirements were slightly different. In this case, there were low-helix splines on the shaft that would have made a poor mating surface. I wanted to get the splines off. Could have brazed on a sleeve instead. Lots of ways to skin a cat.
