A long time ago I had an articulated arm that held a plastic square- a drafting machine. This was pretty basic- for angles you'd use other plastic drafting tools with it. Now I'm finding that I can make use of this again- for my 24 wide x 16 deep pull-out shelf.
The concept is pretty basic- each 'arm' has two control rods with pivots at each end, and there's a two pin mount fixed to the table, a four pin 'inter-tie', then a two pin mount on the plastic square. You can move the square around the table and it maintains its orientation.
I'd like to make one, and because I'm prone to over-engineering things, I'd like some input as to how I should make the pivot points and keep this very simple. It does have to be very low profile, because when the shelf is closed there's less than an inch from the top of the shelf to the underside of the desktop that it slides into. My old one used rivets, and it wasn't too bad, but there was play there. I want zero play, but of course nice action. Has anybody made one of these?
