Request for a dimension on a Grizzly dividing head retainer
  • Request for a dimension on a Grizzly dividing head retainer
    Looking to find the OD of the wiper retainer spring on the Grizzly 1053/1054 dividing head, shown as part # 32 here: https://cdn0.grizzly.com/partslists/g1053_pl.pdf
    If it will work with my slightly smaller B&S index plates, it will be a lot easier to order it from them than to try to make one out of spring steel.
    Thanks,
    Dan Click image for larger version
    Salem, Oregon
    I can't help you with your specific request but I did something similar. I have a Central Machinery, 20" drill press that is very similar to the Grizzly model. I wanted a better depth stop than the one on the CM and that requires a bracket that fits on the quill and holds the depth stop screw. I was familiar with and had used the Grizzly DP so I ordered the Grizzly part thinking it should fit. Well, apparently Grizzly must use bigger bearings or something because their bracket has a significantly larger bore.
    I kept the Grizzly part and will make a spacer ring. But this shows that just because two import machines look alike does not necessarily mean that they are alike in all respects.
    Those spring clips are fairly standard. I would take the dimensions that you need or bring in the shaft and go to a well stocked hardware or auto parts store. You can probably find one that fits. That will be a lot faster and probably less expensive than an order from Grizzly or from the OEM.
