RPC and tombstone welder wiring
  • #16
    Originally posted by Mr Fixit View Post
    That looks like it is NMB cable sheathing vs SO cord sheathing. It does serve a roll in holding the cables together but for the situation of the picture shown, I say heat shrink or friction tape is going to serve you fine without any problem.
    TX
    Mr fixit for the family
    Chris
    Correct. The outer sheath is marked NMB. Depending on where stuff ends up with reorganizing the workshop, I may be able to simply cut the cable at the tear or will simply get new 6/3 since 6/4 isn’t needed.
    • #17
      Just seems like spending money for nothing, but I dunno.
      -D
      I appreciate your concern for my finances, Doozer.
      I may yet have need for 6/4 cable elsewhere, at which point if I use it for this instead of buying 6/3 I’ll end up having to buy more 6/4, which would be more expensive. Still undecided, and all depends on where the rotary panel ends up going with the reorganization.
