Hi Group,
I need to make a bumper brace like the original, it's the long narrow back piece to mount the chrome bumper too on a old car. I have 1.25" x.25" flat stock A36 HRS and I need to heat a section up in the center to give it a cup shape on the .25 width for 12" and want to keep the metal strength after this is done, because I will be putting a bend at the end of this cupped area and don't want to have the cupped area be soft.
I have a plan to us my press with a die set to do this, I plan on taking it to a dull orange color unless someone advises differently and then just air cooling.
So the question is, heat it then let it air cool, water quench it to cool, or another method to keep the hardness of the metal. and is temp a consideration that I need to be aware of?
As you can maybe see, the center is the part that I'm speaking about. This is pics of 2 different parts.
TX
Mr fixit for the family
Chris
TX
Chris
