What the deal with 8620 hot rolled?
When I shop for material (steel round) online, I see 8620 hot rolled as the cheapest alternative to cast iron or 1018.
I am a lowly home shop (garage) kind of guy and generally use whatever unknownium steel I can heist from any fab shop drop cuts.
I am at the point where I want to make more tooling for myself and desire something better known and quality than common soft unknownium.
A lot of tooling is made of cast iron, and that is not cheap to just go out and purchase.
1018 is so common that the price is low, but it is low carbon (soft), not really used in tooling. not known for good finish
Enter 8620 hot rolled. it is a higher alloy, it is cheap (comparatively), so why should I NOT consider that?
Is it particularly difficult to turn? to get a good finish? to finish on a dimension in the home shop?
If 8620HR really is a high alloy, then why is it cheap to purchase?
is there hidden gremlins inside it?
